Think I lost 5th gear towing my travel trailer.
Mox12
Tri Cities Wa
5.7l
I have a 2011 ram 2500 st and I hauled my trailer about 6hrs to camp, then on the way home yesterday the trans would not shift into 5th.
Rpms on meter were really doing funny indication. I limped home but pretty sure I could only get 4gear and was at 2750-3000rpms the whole haul back.
Also, when I would come to low speeds and a stop, randomly my truck was telling me the trailer brake wasn't connected. It did that 3 times.
Any info would be great
NewBlackDak
6.7L Cummins
I would bet a wooden nickle your solenoid pack and/or valve body are bad. If you don't have an OBD reader, go to AutoZone and have them get the trouble codes.
Cmz2800
NC
2025 Warlock
3.0 inline 6
When you’re towing you should always have the transmission temperature gauge on to verify your transmission isn’t overheating.
If I had to guess, the truck threw itself into limp mode to not damage anything.
Just a thought
Sounds like it's time to inspect the trailer brakes, if one of the magnets or wiring is damaged or failing this could cause the trailer brake disconnect.
