those that have aftermarket guages....
derek_m
what are you running? pics?
I plan to add trans temp/oil press/voltage in an a pillar as the stock cluster in the express sucks. just not sure which line of autometers I want to go with....
Power247
High Point, NC
6.4 HEMI
The new Isspro EV2's match the 4th gen gauges perfect if they have what you are looking to monitor.
I ended up going with an Edge Insight CTS mounted to the A-pillar because i wanted to monitor more than 3 gauges when towing.
BlackRamHemi
Edmonton Alberta Canada
AutoMeter Elite Series in an AutoMeter triple pod
Fuel Pressure, Boost/Vacuum and WideBand A/F
I have my Trinity and EVIC monitor all the rest.
You can set up to seven different colors and different high and low warning light colors...
Green LED added over Boost gauge for Water/**** injection indicator
fasthemiram12
Eagle 5.7 vvt
Those look good...
You can always add a evic cluster So you can watch the basics.
Etroze86
Grand Forks ND
Those are sweet guagues and I love my EVIC for basics while towing.
bouf0010
Similar set up, just with aem guages. Wideband air/fuel and a fuel pressure. Waiting on the trinity for 13s and she'll go in the blank spot at the bottom.
shanmccarthy
