Those Without Wireless Charging
Chazulson
Massachusetts
5.7L V8 eTorque
What the hell are we using this spot for? I can see on the models with Qi that it's flat where a phone would go. Mine doesn't have Qi, so this spot seems useless to me right now because the backing is rounded, if I put my phone there it'll just tumble in to the dark abyss below..
New owner of a 2020 Dodge Ram 1500 Big Horn looking for some guidance, loving the truck and the forums have a lot of great info, thanks!
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
What's Qi? My truck does not have wireless charging, but I can still insert my phone in the spot it would be if I did have it. It's just a holder for the phone. I'm kind of confused at what you're describing as the dark abyss.
Chazulson
Chazulson
Massachusetts
5.7L V8 eTorque
Qi is the tech used in the wireless charging pad that comes with trucks that have it equipped. The dark abyss would be the area right below the phone holder, basically the big center storage bin. My phone must just be too big for this spot or the little flaps in the phone holding area are too tight for it to fit in there. All good, minor detail I figured I'd ask about.
mikeru
Super Moderator
Eastern WA
2020 Limited
Ah, okay. Thanks for clarifying. What kind of phone do you have? Does it have a thick case? Mine fits easily even with the case, but it has a pretty slim case.
Narg
Tulsa, OK
5.7 eTorque
Qi, pronounce "chee", (the ancient body power to Asian folks https://www.merriam-webster.com/dictionary/qi ) is what MOST phones have, not all. Some have proprietary wireless charging. You're not missing much. Better to plug in so you have carplay/android auto. Until they make wireless careplay/android auto more available in more vehicles that is....
bluebeast1562
Hemi 6.4L
My phone has the ability for wireless charging but my Ram does not have it, not a big deal, the area where the charger would be is not big enough for my phone in the first place. I just use one of the three USB ports to charge if need be. I do keep my hand sanitizer in that spot, pretty easy to get to.
Chazulson
Chazulson
Massachusetts
5.7L V8 eTorque
Yeah I found that I can get my phone to actually fit if I pull a little harder on the clips in front, I have a Note 10 so it's a decent sized phone. I agree with Narg too about the need to plug in, I wish android auto/apple carplay would function over bluetooth.
Mehgyver
Dayton
Hemi 5.7L V8
on longer trips when i bother plugging my phone into the usb-c port for android auto action i stick my phone down there, never had any issue with it staying put
Matty Moo
Mine fits in there and stays there,i can see some of the larger phones not fitting though.
turkeybird56
Central Texas
On MY 19, Bighorn, I can use Bluetooth for Carplay, I have a I Phone 11, but I choose to plug in since keeps phone charged up... Think I am gonna buy an oversize weathertech cup/phone holder for my phone.........but things are so backed up and delayed on purchases, who knows.
beerthirty
Georgia
hemi v8
I have an iphone XS in a lifeproof case that I usually just rest on the lip. Phone/case is just a little bit too large I don't want to snap it off forcing it in there.
Pjwishlist
East Coast
Yes
Heck, I wish it would utilize the entire 12" screen! Not sure who designed that it only works on the upper half and the bottom is....wasted space essentially. Sure hope soe sort of update comes about that makes better use of the screen. I mean, it was a selling point. Now it is the same size as the Chevy or Ford.
Terry Reedy
IL
Is it possible to purchase and install the Qi charging unit in that area? Does anybody know where to purchase things that were not installed as options on your vehicle? I own a 2020 Ram 1500 Rebel crew cab.
dieseldave
Little Suamico
Is there a USB port that stay on with the key off
bluebeast1562
Hemi 6.4L
I am know that the USB ports stay on for a little while after the engine has been shut off but not sure if they are able to stay on without the ACC pushed.
mikeru
Super Moderator
Eastern WA
2020 Limited
Yes, there is a Mopar kit you can install. I've seen them on ebay. Here's just one of them...
https://www.ebay.com/itm/2019-2020-...968805&hash=item3d94600d00:g:FGAAAOSwNaBd6pJy
I went a different route and just installed an extra charging pad I had laying around. It seems to work fine.
dieseldave
Little Suamico
Dodge 1500 4X4
Rochester, NY
It would have to be wired to be hot all the time, with the parasitic draw these new truck have it could possible run down the battery.
gphilpot1
US
Anyone know if there is anyway to install the Mopar wireless charger unit in an earlier model (2017 Laramie)?
mikeru
Super Moderator
Eastern WA
2020 Limited
Not without a ton of custom work.
