Cravenspeed at Got Exhaust- Antenna's, phone mounts, and more
Nick@GotExhaust
Supporting Vendor
SC
Got Exhaust proudly offers Cravenspeed products
Cravenspeed manufacturers lots of interesting goodies like the Gemini phone mount and several different antennas including the popular Stubby!
The Stubby Antenna
The Stubby is the best aftermarket antenna replacement available for your RAM. We machined our first Mini antenna back in 2005 and have applied our experience to designing a perfect fit.
Made to Last
This model is machined out of billet aluminum in Oregon. It has corrosion resistant stainless steel threads, stands about 3 inches tall and is an exact match for your truck antenna. The finish is a black powder coat that will last forever without fading or chipping.
Options
We have two Stubby models for you. This Original version or you could choose the the Bullet version for your RAM. Also, if you are interested in something unique we can engrave your Stubby for $10. Make sure to put this item in the cart first, then add the customization. It's all about details, right? Here is a chance to add that last detail. Something that no one else in the world has. We don't really care what you want to say; put your Insta handle, license plate, dog's name, or whatever as long as it is 10 characters or less (That's all there is space for; it's a tiny antenna!)
Bullet style antenna( I know a few of you here are really going to like this )
Short Antenna
The Stubby is the best aftermarket antenna replacement available for your RAM. We machined our first Mini antenna back in 2005 and have applied our experience to designing a perfect fit for RAM.
Made to Last
This model is machined out of billet aluminum in Oregon. It has contains 2 corrosion resistant stainless steel adapters, stands about 5 inches tall and is an exact match for your truck antenna. The finish is a black hard anodize that is not going to scratch or chip.
Options
We have two Stubby models for you. This Bullet or you could choose the the Original Stubby version for your RAM. Also, if you are interested in something unique we can engrave your Stubby for $10. Make sure to put this item in the cart first, then add the customization It's all about details, right? Here is a chance to add that last detail. Something that no one else in the world has. We don't really care what you want to say; put your Insta handle, license plate, dog's name, or whatever as long as it is 10 characters or less (That's all there is space for; it's a tiny antenna!)
The UNtenna
Antenna free is the way to be
The Untenna is for folks who have realized that the only thing the radio is good for is literally nothing. It's 2000-something, we have the technology to listen to exactly what we want, when we want, without having to listen to an ad for the shady furniture store down the street or the questionably excited accident lawyer.
What's an Untenna?
It is a CNC machined nubbin made here in Oregon from 6061 aluminum and finished with an extremely durable black textured powder coat. Take a look at the photos, we've made this fit the truck better than any antenna out there (even our own Stubby antenna models). This antenna cap will even eliminate the random chrome ring on the antenna base. The cherry on top is the stainless steel ¼-20 hardware that will keep that bad boy attached to your truck rust free for life. It ships anywhere in the US for free, comes with a lifetime warranty, and the world's greatest customer service. Not that you'll need those last two.
Jam Handles
Be Gone Fingerprints!
The look. We all do it. You've just spent the afternoon handwashing the joy of your life. You park up at the store and while you're walking away you just can't resist a glance back at your pristine RAM and what do you see? A perfectly spotless paint job ruined by two unsightly fingerprints right on the door!
Never again.
With the Jam Handle, you can keep this calamity a thing of the past. Using an automotive grade 3M adhesive backing, it simply sticks to the flat spot on your door jamb, just above the door latch. This allows you to close the door without the need to touch the outside surface, avoiding any fingerprints on your freshly cleaned ride. The Jam Handle is made in USA and comes in a 2-Hole configuration that fits perfectly on your RAM. Putting adhesive tape on your paint sounds scary right? Don't worry, the adhesive is designed specifically for automotive use, and can be easily removed leaving zero evidence that it was ever there.
Gemini Phone Mount
The Gemini attaches directly to the dash of the 4 generation (2009-2018) RAM 1500 trucks using existing mounting points. This makes installation as simple as removing a couple screws and putting two more back in. By attaching the mount directly to your vehicle, you don't have to worry about sticky pads, vent clips, or suction cups. Simply put, the Gemini will never fall off.
The magnetic base, with its one handed operation, is very convenient. Attaching one of the included adhesive metal plates to the back of your phone or case will allow the magnetic base to get a firm grip on your device. .
The mount is made in the USA from laser cut steel and powder coated with a black textured finish. Install takes less than 10 minutes and requires zero modification to the vehicle. Check out the instructions below for more info.
Not sure if you have the tools? No problem, we have you covered with our 8-Bit Tool Kit! The kit includes the tools you'll need to install the Gemini mount, and even some that you won't need! We'd rather have leftover tools than leftover parts.
Contact us for more info and pricing on any of these great items!
TMFMK
