Tie Down Anchors
nortac1
2017 Longhorn
Hello all!
I recently purchased a Ram 1500 Longhorn and cannot for the life of me find tie down anchors for the bed side mounts. They are 1 X /1 1/2 inch and apparently, from searching, nothing is made for them?
Has anyone used the inside bed slots for tie down anchors? If so, what?
Thanks much!
LarryA
Seattle
Hello all!
Thanks much!
I went with "Bull Rings". Pretty easy to install, and look nice as well.
Skubasteve!
I just use 2 chains, one on each side of the truck from front to back, hooked them to the factory corner tie downs in the bed using caribeaner clips. That way I have tie down access points pretty much anywhere from side to side.
N
nortac1
2017 Longhorn
Did you use the Bull Rings in the side wall of the bed?? Or on top of the bed rail?
LarryA
Seattle
Top of the bed rail. I figured with the stock tie down points low on the side walls, the top of the bed rail made sense for large or bulky loads.
Plus the flush mount stainless bull rings look good too!
geneseedennis
