Tire information help
KahneFan
Buda
I'm looking to get some new wheels and I'm learning as I go. At 41, I'm just now getting into wheels and upgrades. Anywho. I think I have most things here figured out except "Bore" and "B/S". Can anyone help me with what our Bore is? I think B/S has something to do with offset, but I'm not 100%. Speaking of offset, is -24 an "OK" offset to run on 9.5" tread, and would a 10" wheel depth look OK on a 10" tread? I think the row I have highlighted should work, but I'm not 100%. Any feedback is appreciated.
BOWERSFJ
Uniontown OH
Bore is the size of the hole thru the wheel ... Ideal situation is that it fits our hub diameter ... The wheel you picked does ... Otherwise you get into the whole hubcentric vs lugcentruc thing ... Backspacing is a function of offset and wheel width ... Tons of charts if you Google it ... Tread width is a minor concern ... You have to look at the section width, or overall width of the tire ... Custom Offset is a good website to search possible looks ... a 10” wheel with -24 offset is fine ... It’s definitely going to move things out ... Fit will all depend on the tire selection, and your lift/level status ... Lots of tire/wheel comparison programs on the web ... Plug in what you got and what you want and it will show you the difference ... Age has nothing to do with what you know ... I’m 56 ... Everything you need to know is at your fingertips ... Just read and research ... We can answer questions ... We can’t tell you what to buy ... Good Luck
