Tire Pressure Monitoring System
alschief
Anderson MO
Cummings 6.7
Just rotated tires on my 2016 Dually. Pu two from tires to rear and had two new tires installed on the rims moved to front positions.
The tire position show correctly but the pressure for all four tires still show the previous pressures. How does one update the readings to display correctly. I’ve driven the truck 200 miles and tried disconnecting both batteries no change. But the new position report correctly.
I did install a premium cluster just prior to the tire rotation, everything else is stock.
JayLuke
SO CA
CTD 6.7L
I had changed my tire pressure thresholds using Alfaobd and my truck kept giving me the tire pressure warning light... then I realized that I forgot to reset the RFID hub, after that the warning light went away and the pressures displayed correctly.
A
alschief
Anderson MO
Cummings 6.7
I’ll look into checking the hub reset. In my instance no warning lights just not reporting actual pressures at each location.
