tire pressure
hookerman
******* 6.7
Tire pressure symbol on dash. The note says inflate tire to 80 psi that seems high. Will this fix the problem?
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
I'd just check the pressure in each tire
does the 14 rams have the pressure readings in the evic?
Tho there not 100% correct there close.
if all the pressures are same or near (give or take 1-3 psi) I just call the dealer and ask them how to reset it, if you cant find it in owners manual
