Tires??
Ram2145
What is the biggest tires and rims I can fit on a 6" lift and 3" body lift?
HKkid
Missouri
Should be able to stuff 37s.
R
Ram2145
Yeah I can fit that with just a 6" lift but was wondering if I can possibly go bigger
HKkid
Missouri
Problem you are going to run into is you are going to start rubbing.
R
Ram2145
Really? Dang I thought maybe I could go bigger but oh well
The Assassin
B-more careful, Murderland
I have a 3rd gen, so take this with a grain of salt...but I am running 38x13.50x20. 6" suspension and 3" bl. I recently added Bilstein 5100s up front, and plan to lift the rear..so, I will have more room. Currently no rubbing issues. However, this is a show truck, not daily driven or off road.
R
Ram2145
I also got the bilsteins up front. So even with the 2 more inches I cnt fit bigger than 38's
reefguy89
laurel de
bighorn4life and musclemceester are running 6" lift with bilstiens and 37's. So add in a 3" bodylift you should be able to clear 40's.
R
Ram2145
Would that be too wide of a tire?
The Assassin
I'd say anything more than a 13.50 is too wide. Not to mention...not really safe for an IFS set up...unless it's a show rig that never gets driven and is a trailer queen.
schroederMP
Indiana
Cummins
I've seen that set up with 38x15.50r20 with no clearance issues. Wheels were 5" backspacing also.
schroederMP
Indiana
Cummins
Rough Country 6" Suspension
Performance Accessories 3" Body
Bilstein 5100's set at 1"
Super Swamper SSR's 38x15.50R20
Moto Metal 955 20x10
Musclemckeester
Houston, TX
n/a
n/a
Yeah with a 6" suspension and 3" body you can clear 40s. Like Dan mentioned the problem is the width. The guy above running 38x15.5x20 measured and said they are actually only 13.7 sidewall to sidewall. I think Interco makes some bigger tires that aren't too wide (in the 14" literal range). Mine are 37x13.5x20 but actually measure 14.1" wide. They clear but only because my backspacing because it's really close. I think some lift kits may allow for a little wider tire too.
Musclemckeester
Houston, TX
n/a
n/a
I think when it's time for new tires I'll probably throw a body lift on a step up to 38s...or maybe something bigger. :D
I will probably go with a tire from Interco though. They are pretty light for their size too which is something to keep in mind.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Go big or go home
quietpeen
2021 TRX
Hellcat
so what are you gonna get?
HeadHunter
38s on it if its a 4x4. as long as you dont try to go too crazy with the width. i had 20x12 on a 2wd with 10 inches of lift and it rubbed when we turned but its also a 2wd that sits lower from factory to start.
