Tis the season
deangtp
Tis the season to wire in heated seats right. When I reskinned my seats I put heat pads in. I didn't wire them in, then it got cold. Didn't want to work in the cold. I got a couple days vacay so I'm trying to tackle it now. I'm running auxiliary back up led pods on the same set of power wires. My question is where should I get power from that won't draw if the truck is off. I don't want to have to worry about switching the seats off when I get out. I was thinking about running a relay like I ran my intercooler pump on my Grand Prix.
baum
savage, mn
2015 Laramie
smart man use a relay. depending on the current draw of the seats you may want to run a direct line to the battery. let the relay trigger when the ignition comes on and then to the heated seats from there.
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
I'd run a new line for power and relay that power. What would be really neat is if you could tap into a circuit with the relay that also turns on your heat. I know I wouldn't want the seat to be heated all the time. Food for thought anyways.
D
deangtp
I was thinking about tapping the radio power wire, that way the seats would stay powered for a few extra minutes.
ameer73
