To level or lift
homebrew
Cummins
Hello all I recently bought a 14 1500 QC , I want to level it but have read about the ball joint issue so trying to see what the best direction is to go. Quick math is about 600 for beilstiens and new UCAs. On the other hand I can get a four inch lift for 1200 or so. What are your opinions?
chipmaker
AZ
I was going to go straight to 4" RC lift. Now I'm going to level w/ Bilstein, then if I want, I will add 4" lift.
iam_canadian22
northern ontario
No issues yet with rancho quick lift loaded, and none reported that i can think of, but if you want to lift later on bilsteins give you the adjustability to level the lift, look into mevotech control arms , they are about 50$ a piece i believe and people have been having great luck with them
hotrodderscott
I installed the Rancho QL, have 4500 miles with no issues abd great ride !
homebrew
homebrew
Cummins
What is the best way to level/lift my truck without voiding my warranty?
DisturbedGator
Bilsteins and mevos here for about 4k and no problems yet
carl0
Hemi 6.1
It will not void your warranty, although they can deny individual warranty claims if they can prove that the cause of the problem is brought by the installed aftermarket parts.
SuperTrooper
Douglas, GA
And they will do this every time because they know any aftermarket suspension part can be used as a scapegoat for suspension/drivetrain problems.
homebrew
homebrew
Cummins
Decided to go with the bilstiens set at 2.1.
sha292929
evansville
can i run 22x10 wheels with -24 offset on 33 tires on 2013 dodge ram 1500 with 2.5 hbs level kit w 1.5 bd lift with no problems
mmwaggie
Hi sha292929, you should post your own thread and might get a better response.
Homebrew, looks good!! stock rims and tires? whats the distance on tire to well front/back?
Ram14Stud
Hemi 5.7 !!!!
I've got a leveling kit on my rig and haven't had any issues....yet :eek:
homebrew
homebrew
Cummins
Update to my post, just added new shoes bfg ats 275/65/20s. Bilstiens set at 2.1 I'm measuring 39in in the front and 39 3/4 in the rear ground to fender.
