I do much the same. BUT it is nice when I do happen to have something of value in the bed, that no one can get to it, even with a big knife.I've had people break into my truck cab, but so far never into my tonneau. If they tried to slice it I'd notice since it's vinyl over steel. That said whenever I go into Vancouver I take everything out of the box and leave the cover open to avoid the temptation. Luckily I don't do that very often.
You would be causing significant damage to the bed of the truck before getting the locks on the Revolver X2 to give. The use a full length aluminum bar down each side, and steel brackets holding that bar in place near the latches.Had a hard cover on last truck for 5 years and with current for another 4 and in that time never had an issue with breaking and entering. In reality while obviously more protection than a soft cover the hard cover panels use plastic latches so if someone really wanted to enter it a crow bar should take care of it without breaking a sweat.
But, as was said, out of sight, out of mind.
Hitchhiker,
Does it interfere with the ram boxes or keep them from opening?
FROM THANKAVETTODAY
AwesomeNope, here’s a pic of one of my ramboxes open, cover closed:
Basically along the bed between the rambox and the bed itself is a two inch rubber seal on the bakflip cover, so the one inch on the rambox side simply folds up along with the rambox when you open it, and folds right back down when you close the rambox. Never had an issue with the seals on either of my RAMs.
I have the Mopar cover too that was installed at the dealer. I have to lift it to open or close the tailgateMy last truck had a BakFlip and on this one I have the MOPAR cover. They are both nice but I do like that the MOPAR does not need to be lifted to open and close the tailgate.
MOPAR cover below:
MOPAR cover below:
I ordered the same one. I don't remember the brand of the last one I had but this one is just as good. I really like it, fits good.I just bought a Tyger tri-fold for around $230 on amazon for my 2018 RAM Quad Cab. The build quality is fantastic, it looks great and is a fraction of the cost of almost all of the other well known brands. This is the second tri-fold that I've bought (owned one for my Titan in 2005). Anyway, tri-folds are very versatile, water tight and the Tyger brand fits RAMs really nicely.
I've had two Bak-Flips previously and loved them outside the opening and closing of the tailgate. With that said, I just installed a Peragon cover on my 1500 two weeks ago. Biggest benefit over the bakflip is that when its open, you can still see out the back window. Not to mention slightly more affordable. I highly recommend checking them out.
