Tow/Haul on 5th gen 2019..Does it disengage MDS or not?
condor767
Virginia
I’ve seen different opinions on this. Anyone know for sure?
2019 Bighorn 5.7
Ohio5pt7
Ohio
Since it's the same drive train as the 4th gen the only way to disable it is to manually shift the gears into 8th. Tow haul wont do it. Or a tune.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Firebird
2019 Ram 2500
Yes, disables mds
condor767
condor767
Virginia
Ok, two different answers... hence why I asked the question :D
Anyone know for sure?​
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Yep other threads on our forum, same result. Some think tow haul disables MDS some say it does not and you must also set your gear selector in 8 in order to disable. Just for the record. the dealers are just as bad with their answers. Really need some of our tech member's to get on on this.
1morepart
2019 Ram 1500 Quad Cab Hemi 3.92’s
Georgia
In short, NO. Only putting it in any selected gear. Ie 1,2,3,4,5,6,7 or 8 will disable the MDS. And yes, a tuner can just shut it off. Tow haul just holds gears longer depending on the grade and weight (which causes the motor to work harder)of the load. On the highway, tow haul mode will easily kick mds on if you maintain a low grade. I have 4 Rams. I’ve used multiple tuners. This is the gospel I’ve learned. JB
