Tow/Haul
jljbtm
I used this button today and seems to lockout 5th.gear and no eco?
Sent from my SM-N910V using Tapatalk
huntergreen
Marine Corps Navy Badge
yes, tow haul changes shift points and locks out overdrive. i believe it will also disable mds.
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
According to Ram engineers Tow/Haul will not lock out MDS, it is still active. Only using the ERS will disengage MDS.
I notice on my 8spd that it will downshift and engine brake as well.
I noticed after the last tranny update mine does this in normal operation too, but not as much or pronounced. Anyone else notice that? Never searched on it, put it in the "under warranty do not care" file...
Devin1349
Question on the ERS, when your in TOW/HAUL doesnt that automatically go into ERS mine does as soon as i hit the tow/haul button it it shows what gear im in ex: press tow/haul then 5 pops up next to my odo.
I use my TH every time I drive, it is second nature at this point to press the button upon startup. Now going on year 7 of using tow haul everyday, I'm guessing it is ok to use. In my 2010, tow haul disengages MDS.
Rzrman328
The treeline
Damm...beat me to it.
That's the first thing I do upon start up.
Zero issues.
Bigbird
Arlington Texas
2017 RAM 1500 QC 8sp, 3.21, Lone Star
Zero issues.
............and what is the purpose of doing this? Just curious. I only use tow/haul when I'm towing my travel trailer.
It changes your tranny gearing to stay in higher rpm's, eliminates bogging and shudder from having the gear in low rpm's. Better control, better power, no reason why not to use it. The question you should ask yourself is what the **** is up with the stock shift points, and why it it every ******* manufacturer has them, they suck ass. Now, Ford has a ten speed and Ram has an 8 speed, all in an effort to eliminate bogging and shudder. But, why not just change the shift points? Maybe, they can't, just maybe the EPA wants them to have engines running in low rpm for CAFE standards.
Rzrman328
The treeline
Exactly.
My ram drives so much better with tow/haul on especially with the 37's....I can tell immediately when I've forgotten to engage it because the whole drive-feel sucks ass.
I bet the stock setups are really peppy while using it.
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Agree with others on my 2011 5 speed. I've been switching back and forth days at a time and TH makes a big difference for the good. Plus it sounds mean as hell coasting down hill.
My MPG actually goes up when driving with it enabled. I don't have a ton of elevation change in daily commute but without it on it shifts quite a bit more.
i push the button as soon as i start the *****.
I just found the new nickname for my truck, the ***** (with respect).
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I do believe they have them upshifting so fast for fuel mileage, keeping rpms down is better for this.
My wifes Mustang is annoying with how soon it upshifts as was my 07 Cummins. I had the trans in my Cummins tuned and it made a world of difference in how that truck drove.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
So I beg the question... Can a programmer auto start the truck in TH mode?
I know not the same sport but... I used to start my GTO in TC off mode, TC ****** me off when I know how to drive my car.
You can custom make your shift points even better then TH if you have a programmer, shut off MDS as well.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
i don't have any performance mods as of yet,so pushing the little button will have to do me,for now.i don't see the cost benefit in a tuner.
clh1220
st Louis
Looks like most here that use the TH all the time don't have the 8 speed. I don't use it except for towing.
