Toyo A/T 3 295/60/20 question
Beagler
Ga
Been running Nitto RG 285/60/20 on stock wheels with no problems rubbing with the Bilstein set at 1.4 ..I'm looking at getting the Toyo A/T 3 tires in 295/60/20... They are 11.8 wide which is a hair wider than Nittos in 295/60/20...Is or has anyone tried the at3 in that size yet and did they rub at all??
BOWERSFJ
Uniontown OH
You should be fine ... I’ve seen 305’s that didn’t rub
8SpdHemi
Canada
I'm running Falken Wildpeaks at3w 305/55/20 on stock 20x9 black sport rims with no leveling kit, tires don't rub. I have a very small wheel spacer on the front wheels to give more clearance between the tire and the UCA/balljoint.
Lowrider357
