TPMS Intermittent Beeping and TP Icon flashes
mhazell61
Bradenton Florida
I have a 2023 Ram 1500 and bought new tires and Ram wheels. I had the dealer install new TPMS sensors. Ever since then I get an intermittent beeping sound and corresponding TP icon flash on the dash. It happens
dozens of times per day. The dealer says I need a new TPMS gateway/hub for $750 yet I had no issues with my original 17" factory wheels. I changed to 20" factory wheels that did not have sensors. The dealer also said that they could not warrant that the gateway/hub is actually the problem. Any ideas kind folks???
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
What brand TPMS sensors were installed? If you put the old wheels back on and everything works OK, that means he failed miserably in the reprogramming process, as the old ones shouldn't read either, if he did it right.
If the OEM ones work OK, it's not the hub. It's probably a situation of the sensors not programmed correctly and confusing the hub.
May have to reset the RF hub. See this thread:
