kurek
- Joined
- Aug 7, 2019
- Posts
- 2,664
- Reaction score
- 3,822
- Location
- Northwest
- Ram Year
- 2015
- Engine
- Hemi 5.7
To be clear I know I can simply turn off TPMS entirely with JSCAN but if it didn't completely suck it would still be handy both for safety and convenience. Nannies are fine in principle but a nanny that is objectively wrong is unacceptable.
Here's the problem; the factory setting for minimum pressure I think was around 40psi which meant if I had them at 45 in the afternoon at least one would be down to 39 first thing in the morning while the air is cold... and then I'd have this dumb warning flashing at me for several days because it doesn't just reset when you - or the sun's warmth - fix the problem.
So I used JSCAN to set the minimum pressure to 25psi, problem not solved. For some unknown reason now if it falls to less than about 32psi (not 25 and also not 40) it tells me to "fill to 25" .. and just like the factory behavior it takes several days for it to reset even if I fill the tires.
I recently got new tires and new TPMS sensors, behavior hasn't changed.
Aside from just venting, does anyone else have a different experience with TPMS? Does yours reset right away when you fix the problem?
