etuke
So the TPMS light came on the other day on my 2014 Ram outdoorsman,happens as the weather gets colder.I filled the tires to 34 PSI as where I wanted them for a bit smoother ride and the monitor read it correctly but the light remained on.I decided to use ALPHA OBD to lower the pressure threshold to remove the light on the lower pressure.So I set it to 30 PSI and reset the hub and the light went out and the pressure was showing 34 PSi on the dash.I thought all is well untill I noticed it doesn't change as I'm driving now and the tries warm up which worked before the reset.So I decided to put the tires to 40PSI to force it to change but it stayed the same.I drove the truck over an hour at highway speeds and the pressure never changes.Light remains off so thats good.I have since reset the pressure thresholds back to 39 PSI and reset the hub numerous times but the tire perssure remains at same PSI from the first reset.I did a sensor roll test and it say none of the sensors are detected.I checked the antenna behind the rear seat as I had issues with it when I first bought the truck but its fine and the remotes all work fine.Its seem it all started on my first hub reset and now its stuck on the reading it got from it.All the sensor wouldn't have quit at the exact same time and if they did the pressure should be empty on the dash.Am I supposed to reset anything else besides the hub to register it again?
