Trailer Tire Pressure Monitoring TTPMS
SniperDroid
Eaton Township, Ohio
I'm getting ready to attempt adding this to my 2019 2500 Bighorn, and was wondering if you could provide the parts? The Part numbers I would need should be as follows:
68375990AC Bumper Receiver
68404893AB Headliner Module
68412666AA TIM Pigtail Cable
68433188AA TPMS Sensors Kit
I got the info and instructions from another Forum, had a tire go south on me on a camping trip last week. A Good Guy pointed it out to me, at 60 miles an hour, that I had a flat on the Camper. Don't want to go through that again. If there are compatibility issues please let me know...
Thanks
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Bschmoyer
Honesdale Pennsylvania
I just installed mine on my 2021 ram 3500. It is a limited trim package. All the pig tails were there. I ordered the receiver, gateway moduel and the wiring harness. I used the alpha obd2 to turn on the sales code. I had to turn on two separate locations under vehicle configuration. Works well! Now I need to find info to add the telematics
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Does anyone know if this is even possible to add on a 2018 Limited? I have AlphaOBD already.
Bschmoyer
If it was a factory option I would say yes. On my 2021 it was an option that I didn't order and regretted it. I found the modules and pigtail to add to the truck and turned on the option with Alpha.
Cbeurbe1990
Michugan
6.7 cummins
Hey do you happen. To know where the harnesses are? And part numbers? Than
ks so much
TMFMK
