Train Horn Problem
MvZiC MaN
Port Charlotte Fl
3.9L 295 CI Magnum V6 :(
I have a Horn Blasters Shocker classic228 train horn that I just bought installed and I need help with the wiring. My solenoid is not activating and I have it wired as my instruction manual shows, one wire from solenoid is grounded, the other runs to the toggle switch( to activate horns ) and the other wire from the switch to the positive battery terminal. I also tried just running the wire straight from the solenoid to the positive battery terminal but it still won't click.
I just payed over $500 for this and its not working please help!!!
TexasRammer
College Station, TX
Make sure you have a good ground, and make sure all of your connections are good.
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
I have double Checked all my Connections and the solenoid is grounded to the same spot as the Compressor.... and the Compressor works just fine
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
Yup i have everything hooked up according to the instructions
TexasRammer
College Station, TX
Try switching the hoses around on the solenoid, sometimes if theyre backwards it wont work. If that doesnt work, I would say its a bad solenoid and send it back to hornblasters
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
I was trying to avoid sending it back but it looks like im gonna have to
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
Is the Solenoid Polarized? the directions say use the red wire for positive + and the black for ground - but both wires coming from the Solenoid are grey
loki223
Spokane, WA
Cummins 6.7
is there any distinguishing marks on the wires to see which one is supposed to be which? you could try switching them...never messed around with a train horn myself and i'm no electrician, but i would probably try switching the wires and seeing if it works.
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
Just Tried that and I think its a bad solenoid... Ive already talked to customer support and im sending it back for a replacement 2mrrw
TexasRammer
College Station, TX
It shouldnt be polarized, i just bought a hornblasters solenoid and it doesnt matter which way you hook it up
Stangshcky12
Oshkosh, WI
5.9 Cummins
Check with a multimeter that there is power coming from the switch
My solenoid only has a hot and a ground do I'm not much help
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I would say you just got a faulty solenoid it you wired it directly and didn't click. Maybe get a replacement from them.
Raadz
