Tranny issues
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Ok so I have had trouble since July 4th weekend, I don't drive my truck at all so it hasn't been an issue, but we are looking at going camping again soon and need it to pull the trailer.
It does not want to shift to 3rd after it has warmed up, usually around 20-30 mins. I have taken it to a tranny shop and he hooked up his computer thing. Said 2nd is sending the signal, but 3rd is not receiving it. Says could be the units themselves or there could be some material clogging it. They need to drop the pan to determine whats next.
Anyone else have issues like this before and your solution? Trying to prepare myself for a couple hundred dollar bill or the big $$$ bill of a new tranny.
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Sounds like what your mechanic said. could be a simple fix.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Luke ya can drop the pan and see how bad it looks in not alot of time. If you trust the shop then you can use them and save yourself from having to buy trans fluid twice.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have never done a pan drop, how much does it usually cost for new fluid, and filter doing it myself? I can just use basic fluid to refill for now rather than synthetic
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Tony and Mark would be the best one to tell you about the stuff on your trans to be certain.
JP03
New Jersey
Cummins 5.9
got my trans flushed the next time i dove the truck it blew they blast air in to it and it throws dirt thats in ther all around and screws it up
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
OK so I am going to drop the pan and change the filter out, hoping maybe its just a clogged filter, but will be looking at the stuff inside.
What bad stuff do I look for besides metal shavings? Is there any part I could unbolt and just clean up that would cause problems?
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
So I went out to take the pan off to let it drain over night. Either I got REALLY strong or the bolts were not tight, more like hand tightened, and I found one missing too. Would that cause it to mess up, or should I still just drop it?
I want to let it sit overnight to get the most drainage.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I said screw and dropped it. What should the magnet look like? Fluid? and what parts should I look at, oh and photos help me a ton
thanks for any help
rambob
LA/MS
318 5.2l
it may be a dark red. the darker the older it is.
some metal on the magnet is normal
wierd swirls in the fluid may be water or some other fluid
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
This is what I got.
txbass06
NE Texas
5.9 Magnum
From what I can tell from the fluid on the bottom of the trans, it looks good to me. What did you drain the fluid into? We're there any different colored swirls in it?
Sent from my iPhone 4 using Tapatalk
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Nope no discoloration. just red metallic. No bigger pieces of metal either.
Is that too much metal on the magnet?
Been reading some too. Thoughts on governor pressure solenoid
ramthis9501
Oklahoma
5.2 V8
Looks fine to me. We've changed the fluid in mine twice since I've had it and it looks just the same. Metal shavings are normal since it's just normal wear and tear. As long as there aren't huge chunks of metal then your fine. The filter might be the reason it wasn't shifting. Also just cause, make sure your transmission relay is good, about a month or two ago I pulled mine out without knowing and it threw it into limp mode. Without a good signal, these transmissions are pretty much useless. A new relay is like $10-15 bucks at autozone. Good luck hope it works out
ramhunter9
P-Star Jeep Wrangler
rut ro ....
I can get you the number to a awesome tranny place that builds them if you need .
From what the guy that I bought this truck from said that is what was going on in this truck . He didnt mess around and had a new built trans installed with billet internals .
RubberFrog
That fluid looks fine. Do you have a new filter for it?
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I will be picking that up tonight. My softball game is right by the parts store.
Dave I am trying to try some cheaper fixes to see if thats it. But if not I may get with ya for the number. My dad has friend that builds cummins pulling trucks and does trannys too so he may get it.
RubberFrog
I can't speak to the 2nd gen, but I know on the third gens they do all sorts of crazy stuff when the filters get plugged.
Also, install a drain plug on that thing and if you need to drop the pan again in the next week or so you can reuse the fluid.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yeah I wanted to install a drain plug too while I am at it. This should make for a fun evening, as I am trying to get it back for a show on Wednesday.
From another site (terry aka tactransman) was told could be the direct drum seals, which requires an overhaul boooo
txbass06
NE Texas
5.9 Magnum
I've got a fluid and filter change coming up for mine. Hoping that'll solve my problems...
