Tranny problem or torque converter?
BakedZD
Ny
318 magnum
I have 93 d150 with a 318, when I put the truck in reverse or drive. I have to rev it up at bit for it to "catch" and start moving. Its a problem that started a few months ago but it would only do it here and there. Any ideas?
crazzywolfie
under the truck
Have you tried checking fluid level with the transmission in neutral? Sounds like you are low if you have to rev it for the truck to start moving
B
BakedZD
Ny
318 magnum
Yes the fluid level is good. Recently changed the fluids
nikwho
Flagstaff, AZ
That sounds like your problem is torque converter drain back. Could be from leak in converter (weld, perhaps) or a bad seal around the converter. If the converter can hold a vacuum, it will keep its fluid inside of it, for quite some time. If they will not hold a vacuum, they will allow a good portion of their fluid to drain out of the converter, back into the pan, often also showing dipstick and shifter/selector shaft seal leaks, as the fluid level is high in pan after a short period of time. A Torqueflite 727 doesn't pump trans fluid in park, which is why you need to check your fluid level in neutral. So, once placed into a gear that DOES pump fluid, the torque converter must fill itself back up before it can build enough line pressure to move your vehicle. When you feel the surge is most likely at the moment that your torque converter is again full of ATF and builds line pressure.
Orca
