transmission cooler lines
machsilver
colorado
got a leaky trans cooler line 2009 ram 1500. do the lines easily disconnect with a tool like an old school fuel line tool? what tools have you guys used
If there's a plastic cap over the fitting,you slide or pop that cap back,and under it there should be a small C shaped circlip that you pop off,and the lines should pull out of the fitting. A small pic should help to pop off the circlip.That's if they're the same as the later trucks. Don't lose the circlips as they like to take off when you pop them off,and pay attention to which line goes where,so you can put them back in the same fittings.
