Transmission heating
RDP
Cummins 6.7
I HAVE A 2009 CUMMINS 67 WITH 6 SPEED AUTO. CARRYING A 11,000# LOAD I USUALLY RUN ABOUT 70 DEGREES ABOVE OUTSIDE AMBIENT AIR TEMP. EXAMPLE 80 DEGREES OUTSIDE THE TRANS RUNS 150 DEGREES + OR - 10 DEGREES WITH EXCEPTION OF PULLING A SIZEABLE HILL FOR 15 MINUTES IT WILL HIT ABOUT 170 DEGREES. I AM COMFORTABLE WITH THESE TEMPS.
THE PROBLEM COMES WHEN PULLING IN TOWN, STOP LIGHTS, STOP AND RESUME SPEED, ETC. THE TEMP WILL CLIMB TO 200 TO 220 WHICH I IMAGINE AS LACK OF AIR MOVING THROUGH THE TRANS COOLER. I BELIEVE THE CLUTCH FAN IS WORKING OK BUT I WOULD THINK THE FAN SHOULD KEEP THE TEMP DOWN MORE THAN IT IS.
WHAT DO YOU THINK? WHAT IS YOUR COMPARABLE RIG DOING? :crazy:
dearchristopher
Galveston, TX
not sure what mine runs in town but my diagnostic tool showed 156 degrees with about 3k pounds behind me in a head wind at a constant 65mph. you could possibly try to relocate the trans cooler down to the lower air dam and put an aux fan on it? that is a popular choice with trailblazer ss guys and something I ended up doing. never had heat issues
Sent from my LG-D850 using Tapatalk
