Transmission need it ! Got it
ramhunter9
P-Star Jeep Wrangler
For you CTD guys worried about the trans and the power you are pulling ....
DBTC offers... Entire race transmissions , clutches , TQ converters , Trans pans , Master overhaul kits , Billet shafts input output and intermediate , Valve body's , Trans Coolers , ect..
For 1989-2012 CTD !!!
PM me if your trans needs a upgrade .
Here is a trans special that is a must have for that trans to run and cool at its max ....
BD-Power In-Line Transmission Filter Kit #1064017
94-07 Dodge 5.9L Cummins 47RH / 47RE / 48RE Trans
$230 free shipping to lower 48
•BD's Transmission filter kit protects your Automatic Transmissions against contamination in the transmission fluid
• Eliminates contamination from prior transmission failure or excessive wear and secondary damage to other parts once a part failure has occurred
• Extends Transmission life by minimizing wear by preventing sticking and scoring of sensitive shift control valves.
• Added oil capacity adds cooling capacity
• An off the shelf oil filter has a bypass valve and prevents formation of sludge that blocks passages
• Designed for easy installation the kits come complete with all required hardware with large hoses and fittings that result in high GPM levels even under extreme use.
ramhunter9
ramhunter9
You know it
reddot
Wolf Point, MT
5.9 cummins
he has his tin foil hat on :p
Tapatalk Addict
Had to put a second layer on. He still got me with the alt and starter. lol
This will happen just not too soon. Ill let you know when Dave.
To the rest of you. You only think you know me that well. lol and I guess you do......but my pockets arnt that deep......yet.
Reticle918
