The Trinity comes with a suction cup mount that you can put on your windshield or dash. many guys go with the Bullydog single gauge pod and just use the Trinity gauge pod adapter. Links to both of these are below...
Bullydog A-pillar Single Gauge Mount 2009-2012 Dodge Ram
DiabloSport Trinity 2 1/16" Gauge Pod Mount
And here is what it looks like installed...
I went a different route with my bullydog. I Velcro mounted mine to the empty pocket just left of the ac control. Drilled a hole in the bottom of the pocket for the wire to go through. This way doesn't blatantly advertise to everyone like the pillar mount does.
Glad to hear I wasn't the only one that had trouble with that screw, I was starting to think I was on crack.
Can you post a pic of this? I was hoping to take advantage of that pocket as I never use it, but have not messed with it because I didn't know how to remove it and didn't want to drill without knowing where everything is located behind/around it. Thanks in advance!
http://www.ramforum.com/463313-post114.html
It should go behind the pillar through the pod adapter like shown in the link above.
