Trouble removing 4th gen seat bolts
OnSale
5th Gen Crew
Philadelphia, Pa
So I knew my Milwaukee Impact Driver would not get the massive bolts out for my seats. Doing it by hand is extremely tiring considering I can only turn the back bolts 1/5th a turn at a time due to having a regular cab.
I went out earlier and bought the M18 Milwaukee 3/8 Impact Wrench and thought “ok this will rip those suckers right out!”. Boy was I wrong. It barely got one out, and it literally broke the 18mm impact socket on the second one.
I can’t think of what else to do. I literally spent $240 on a brand new M18 Milwaukee Impact Wrench and it just wont get them out. The driver side front 2 came out with my stupid M18 impact driver, but the backs I bought the impact wrench and the one still won’t budge. I got it out about 20% by hand, after 15+ minutes of small tiny turns.
What specific ‘non-air’ tool are you guys and gals using to get these massive sob’s out of the floor???
This has held me up with my new seats for the past couple days now and is driving me nuts. I’m returning the Milwaukee impact wrench to Home Depot in the morning as it’s useless and won’t get the job done.
Looking for specific tool model #’s for anyone who has removed the main bolts holding in the front seats of the 4th gen Rams.
PS: Yes I used a ton of WD-40 and I also tried PB Blaster, neither of which helped at all.
cgreen107
Wake Forest
Mine were a pain to get out. The only way I got them was to spray with PB blaster from the bottom, and take a long 3/4 drive ratchet and move it small little turns till it broke loose
John Jensen
San Diego County
Ecodiesel
I ended up using a long 1/2" breaker bar with a pipe length added to it. Yes, a bit at a time but the only way. I too have some powerful impact wrenches that could not do it.
rod from md
northeast maryland
pb blaster, patience, and a breaker bar for me as well...did my seat cushion sunday,,took longer to get the two back bolts out than it took to do the cushion replacement
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
yup- did the rear seat mod on my crew cab but a long breaker bar helped.
Freed127
Tamaqua PA
Breaker bar and kroil. My bolts laughed at my impact as well
kad
Hudson Valley, NY
5.7L HEMI
1/2" Ratchet was all I needed on the driver side and a 1/2" x 24" breaker bar on the passenger side.
The socket that broke, was it an impact rated socket?
-K
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
-K
Yes. Home Depot must have an exclusive license with Husky because they only sold Husky sockets, and they had 1 other set that was Milwaukee but no employee could locate them, but the site said the store had them. Anyways, yes the Dewalt 20v XR 1/2” impact wrench just annihilated the husky impact socket in under 30 seconds. Cracked it down the side, and the part that locks into the Dewalt 1/2” drive, it just shredded and became a circle, instead of the square shape. Returned them and got a refund. They were like $50 too. Went and bought some craftsman impact sockets from Ace Hardware and they were atleast twice as thick sidewalks compared to the husky sockets.
But I got the seats out, swapped them, and all is good.
Reactions: kad
VelocityC6Z
Maryland
This. I've been a pb blaster guy for 20 years... discovered Kroil and never went back.
Spray from underneath as another has mentioned, mine were rusted through.
3/8" impact isn't going to take them out,you need a fairly healthy 1/2" drive impact and 1/2" drive impact socket. Took my bigger 1/2" drive cordless impact to even pull the back seat bolts on my wifes Challenger. 3/8' impacts are pretty light duty,especially if they're cordless.Spring for a decent sized 1/2" "brushless" cordless impact if you can,you'll use it alot more then you think.
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Yea I picked up the 1/2” Dewalt 20v XR and some craftsman impact sockets and it tore them right out.
kmrtnsn
Ventura
Mine came out with a 20v cordless drill with a socket adapter.
Purplert
I’m surprised my two Milwaukee’s have handled everything I’ve thrown at them over the years included the seat bolts.
Go buy a lottery ticket,as you're probably the only guy to ever pull seat bolts with a cordless drill.I think you better buy yourself a lottery ticket,while lady luck is smiling on you,lol
Renfro
Colorado
Snapped the head off of one of the front bolts while tightening my drivers seat last weekend, and it wasn't even at torque.
Sent from my SM-G981U using Tapatalk
Bob Macknight
surprise az
6.4hemi
If you have the time,get under the truck and take a wire wheel to the exposed treads of the seat bolts and remove as much of the thread locker used from the factory as you can,will make the job a littler easier
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Got them off almost 2 weeks ago now. Got my seat swap done. Ended up that I needed a Dewalt 1/2” 20v XR Impact and it just ripped them right out.
Arturo Rojas
