My 2004 Ram 1500 with 70K on it had ball joints replaced last week (both upper and lower on both sides) and they had the alignment done by a shop. I picked the truck up and noticed it was pulling to the right pretty bad. After talking to the shop that did the work they mentioned tire pull potentially causing the issues. I was changing brakes over the weekend and swapped the front tires (left to right) and the pull was still there to the right. I took it back to the alignment shop to check the alignment and they said it's spot on and once again it was a tire issue so they swapped the tires from to to back (putting a tire with slightly more tread on the front right (had a flat on the back right a little bit back) but the truck is still pulling to the right.
Any suggestions on how I should proceed? I was going to call the mechanic shop and talk to them but I was hoping to have somewhat of an idea to what I could point to. Does anyone have any insights?
