Patriotswrath
I mean on the Hemi the driver's side plugs are a PIA to do... But totally doable. There's really only one cylinder that's truly tough because it's right next to the brake booster. However, with some short extensions and a swivel, you can get them done and even manage to use a torque wrench on all of them.
If you don't want to do it yourself, an independent shop would be cheaper. I'm sure they "check" the wires that go to your coils, but that's about all they could be doing for plug wires. The air filter is a 5 min job. Plugs are completely possible for a first-time DIY in about an hour. The passenger side takes maybe 20 mins. The driver's 40-60 depending on your pain tolerance and contortion skills. The sixteen plugs are about $130 as said earlier.. But no that's a crazy price for the work being done. That's like 3.5-4 hours of labor.
Also watch what plugs you get, the 2009-2013 plugs are non laser iridium and are cheaper. The 2017 lasers are more if you want to stick with the OEM plug.
