turn signal issues
cook10000
I have 2005 Dodge Ram Qaud Cab . i do not have eather the right turn signal or brake light at the trailer conection i have traced the wire to the fuse box with nothing to it . I have power throught all the fuses help im at my wits end
C
cook10000
right turn signel issues
i currently do not have a right turn signel or brake light at the trailer connection at the rear of my 2005 ram 1500 quad cab . i have traced the wire all the way to the fuse box i have power on both sides of all fuses that go to the trailer.:shooter: help!!!!
quietpeen
2021 TRX
Hellcat
Welcome to Ram Forum. Did you check the bulbs on the trailer? If you have power in the wire, it could be the bulbs or the connection at the bulbs.
treefg
Forest Grove
This spring I had the same problem, except all trailer wires had no power yet good fuses. Found that I had to replace the fuse box, now everything works great now.
HemiBabe
DFW
Hope you get it figured out, welcome to RF
joshhhh
