Turn signals.
Bcn0783
Cummins 6.7
I have a 2015 Ram 3500 I'm needing to install a flash module on. It's needing to be hooked up to the turn signals. Is there a place under the dash I can tap in to the wires that would send signal to all 3 lights on each sides signal. I'm trying to avoid having to run a bunch of wire and connections to six different signal lights.
adurm
FL
2015 RCSB
Unfortunately, I believe its built into the BCM and you probably cant access that.
