Type of oil in these old girls???
SYKRAMMAN
Banned
Jersey shore
06 Mega
Whats everyone running in their tired engine? What's the best additives to keep wear down? I have an 02 4.7 with 107xxx and it's ticking away, it's not any manifold bolts or anything like that, it's a valve tap or similar. I've used everything under the sun and it won't shut up, although it did run quite for about two weeks when I added restore. So what have/ are you guys running?
SYKRAMMAN
SYKRAMMAN
Banned
Jersey shore
06 Mega
Actually no I haven't, hard to find near me. I've heard pretty good things about it.
SYKRAMMAN
SYKRAMMAN
Banned
Jersey shore
06 Mega
Any type of additives? Something with a high moly and zinc.
ST-8
I run synthetic 5-30 in my 04, always have run that weight since I bought it with 56k miles(working on 123k now) The brand tends to change, right now it has pennzoil. Mine has burned oil since I've owned it an has gotten a lil bit worse overtime I think but I have beaten the **** out of the truck over the last 7 yrs so I'm not really suprised.
Ian_Olivas
San Antonio,Tx
4.7L Magnum
I run valvoline 5w30 high millage in mine. I'm burning through oil like crazy but Its worn rings and valve seals from 215k miles still runs good though
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
Plain mobil 1 high mileage 5w30 that is what I put in all my cars and such.
xtremewlr
Tucson, AZ
Shell Rotella T6 5w-40. It's engineered for diesel engines but works great in gas engines. I use it in motorcycles too. I do add a bottle of Restore when I change the oil in the truck as well.
HemiLonestar
Navy Badge Coast Guard
MD
This in the truck and the 5W-20 in the cars (MDS).
fastf
Georgia
That is what I put in my truck 5w30 and my wifes mazda 5w30 and my Bike 5w30 all mobil 1 I put high mileage in my truck I didn't buy the truck new but If I buy a new or used car it gets Mobil 1 in it .On the filler cap it says 5w30 and that's what goes in it.
SYKRAMMAN
SYKRAMMAN
Banned
Jersey shore
06 Mega
I'm trying to stop the dry starts, nothing I use helps. I think I have to drop pan and check pick up screen.
Immortaldaul
San antonio tx
5.9 magnum
Use conventional valvoline in mine. The truck is 15 years old there's no way off knowing what the previous owner is used and I'd prefer to not have risk oil leaks which I was told by my mechanic switching to synthetic could possibly cause.
Sent from my Moto G (4) using Tapatalk
SYKRAMMAN
SYKRAMMAN
Banned
Jersey shore
06 Mega
Yes that is true because the molecules in synthetic are much smaller than conventional oil, so the synthetic oil finds leaks easier.
HemiLonestar
MD
This isn't so much a problem as it used to be...when synthetic was introduced most domestic engines were still using cork gaskets, etc. If it was old enough synthetic would find its way though. Damn near every seal on these engines is an o-ring, so unless its been baked hard as a rock (not likely, they're pretty resilient) you're good. I haven't bought any of mine new and switched to synthetic as soon as I got them. All good and no leaks.
BigBlue05
Eads, Tennessee
I run Pennzoil platinum after hearing a lot of good things about it. And I have to say I'm pretty impressed. Also if your truck is ticking it could also be an exhaust manifold leak. Not sure if you've checked that or not but it's a common problem on these 3rd gens.
cs300823
I just picked up a 2008 Ram 1500 4x4 Hemi and was going to ask same question..in past years I have always ran synthetic but this ole lady has 123k and runs great so figured I would do the same and change it over !! ;-)
SYKRAMMAN
SYKRAMMAN
Banned
Jersey shore
06 Mega
Yes, every time I get a new to me vehicle, first thing I do is flush and change out all lubrication fluids and plugs then i see what else it needs as I drive.
blackbeautyhemi
Lewistown, PA
I switched to redline around 110,000 and my engine is quieter than its ever been.. runs great with it! Worth the extra price in my opinion.
ChloeBrooks
