Uconnect & Iphone BT Music issues
LustinJam
HEMI
I've read tons of threads about the issues with Uconnect and Iphone issues but with no definitive answer. And no suggestions that have helped my Verizon Iphone...
I have read that the Verizon Iphone has a different/new software installed & an update needs to be set to the truck.
My question is where can I get this update? Link? Dealer?
The skipping and speeding of the music drives me NUTS!
EDIT** I have the 430 RBZ - Touch screen without Nav
300MAG
Which radio do have?
Sent from my Desire HD using Tapatalk
LB3711
Trumbull, CT
3.6L V6
mine does the same. i run my iphone thru the aux jack with no issues. bluetooth is just good for phone call use only
L
LustinJam
HEMI
Have you taken it by the dealer for possible software update? I heard that the Verizon phones had a software adjustment that made them glitch with these head units. I just figured they'd have a fix for it by now....
quietpeen
2021 TRX
Hellcat
lb3711 has an at&t phone so it must not be verizon related
LB3711
Trumbull, CT
3.6L V6
Yes plus I have the RBZ radio too. Also you can't plug you Iphone thru the USB jack in the upper glove box and it wont work. Far as I know there is no TSB for an update for the RBZ.
Though I will check in 2 weeks when my truck goes in to the dealer for work.
L
LustinJam
HEMI
If you could ask when you're in, that'd be awesome! I don't see why this issue wasn't a quick fix...
L
LustinJam
HEMI
as per dodges site i think they support up to iOS 4.1.
Go here and check RAM - UConnect. They say for the RBZ for the iPhone is 4.1
Good eye, it says the radio is compatable for the 4.2.6 Verizon Iphone software. Guess I might need to look into downgrading....
LB3711
Trumbull, CT
3.6L V6
lol not me. I'm good with the aux jack. not worth the downgrade to me
300MAG
Update for this fix is 08-36-11 rev a..
Google it and you should find the tsb and other forums have link to software update.
LB3711
Trumbull, CT
3.6L V6
that only works if you dont update the iphone past 4.3.5 iOS
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Did you call Mitsubishi at 7344536200?
$miley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
They are the ones who make the RBZ unlike the others on that link I put up which are Harmon Becker.
$miley
KAKA
