Unknown Opening in Top of Engine
jalbin
5.9 V8 Magnum
So I just bought a 1997 Dodge Ram 1500 SLT with the 5.9 V8, and I've never owned a dodge before, but I'm curious about this opening in the top of the engine. I apologize in advance for my lack of knowledge, but I've only very recently gotten into working on trucks. I've attached a picture of what I'm talking about.
Now I'm not the most experienced wrencher, but should this not be covered somehow?
crazykid1994
Take a picture farther away. Is that passenger side?
J
jalbin
5.9 V8 Magnum
Update
I'm not sure. Here's a further pic. Could you briefly explain what a breather is?
WilliamS
Tampa FL
stops pressure from building up in the heads. Needed for proper oil flow. If it were blocked the pressure in the cover could prevent oil making it up the heads. Usually 1 will go to the intake path to apply a slight amount of vac, most cases it will have filter or some type of cap on them.
Google crankcase breather for your motor.
crazykid1994
Nope. Breather is there. Take a pic of the other side too
J
jalbin
5.9 V8 Magnum
Other Side
This is what the other side looks like...
J
jalbin
5.9 V8 Magnum
Yes, the original picture is the passenger side.
J
jalbin
5.9 V8 Magnum
If so, do I need to cover it? Install a new breather or something? I also have a small oil leak that I haven't started looking for. Could that be it?
Wise
Harrison, Ohio
Yes it needs to be covered just stop by an auto zone or whatever you have around you and get a push in style breather cap since it's not cut out to fit a regular oil cap
Wise
Harrison, Ohio
Some come cut out for two caps with two punch outs for a pcv and breather
J
jalbin
5.9 V8 Magnum
Awesome, thank you for the help. I found it on the Autozone website for like $5.
Wise
Harrison, Ohio
No problem depending on what style you go with you may need a rubber grommet for the valve cover side for it to push into. Also to answer your question yes this could be the source of your small oil leak if it's in the same area.
J
jalbin
5.9 V8 Magnum
So other than cramming this sucker in there, is there anything else that needs be done? It looks like it has a place for tubing on the outside of it. It doesn't need to be run like the PCV valve?
J
jalbin
5.9 V8 Magnum
No hose, the breather cap from Autozone just has little outlet on it. I wasn't sure if you had to put anything on there like a hose or a filter or something. Sorry, I have absolutely no knowledge on breathers.
Wise
Harrison, Ohio
No worries they should have several kinds just get one without the inlet for the hose
J
jalbin
5.9 V8 Magnum
Sounds good, thank you again very much!
