Upper ball joints look un seated.
HemiBrother
Pennsylvania
Just replaced my upper and lower control arms on my 1500. Truck has RC 6” lift was on truck when I bought it. Ball joints were flush when installed and after drive to work I gave everything a look over and noticed them no longer flush. The originals was flush on driver side and passenger side had gap. But now both new ones have gaps do I gotta return these arms and go with aftermarket’s? Both sides look like this.image.jpg
62Blazer
Midwest
I would think they should be flush, and they definitely shouldn't change. Did you install the balljoints in the new arms, or did them come pre-installed? There is a snap ring retainer installed, right? If so, did it fit tight?
HemiBrother
HemiBrother
Pennsylvania
Ball joint came installed already on control arms and yes there’s a snap ring on the under side. The gap was between the control arms and and snap ring but after a drive work that gap is now flush with underside and gap is now on upper side of control.
Daw14
South Florida
That looks suspicious, not very many are happy with RC lift kits .
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Should not have anything to do with the lift kit.......I bet the old uppers were seated.
smoothee
St. John's, NL
I have new set of Moogs that I noticed both have a gap like that underneath between the snap ring and the arm. And I just installed a new Moog ball joint into my Core arm and it's the same thing. Didn't seem right to me either but I can't see it being a fluke in all three cases
Steve58
