Used PCM key programming?
john p f
Oklahoma
I have a used PCM off another 2006 Dodge Ram 1500 5.7 2x4 , same everything. I was wondering what the easiest way to get my keys to operate it is?
I don’t care if it has my VIN programmed or not.
Long ways to a Dodge dealership.
It will start and run for a few seconds before the security cuts it off. Swapped them back out after verifying it runs.
I believe mine could be bad.
HemiLonestar
Navy Badge Coast Guard
MD
You can't unless you find a way to get rid of the SKIM (check your other post). Once a SKIM is initialized to a PCM it cannot be used with another.
joshhhh
