VHT Nightshades
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So I want to redo my tail lights today. I'm going to strip whats left of the nightshades and respray them. Any tips to getting a great finish out of them? How long should I wait between coats and is wetsanding necessary? Thanks for the tips in advance!!!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Wetsanding gets the smooth feel to them, and then after buffing them out you get the smooth shiny feel. Don't know how it would turn out without wet sanding.
nim81
Fredericktown, MO
5.7L
w/o wet sanding they dont shine very well and just dont have an overall finished look to them.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
how long should i let each coat set up? and what grit sandpaper should i use to wetsand with?
BlackedOutHemi
DFW, Texas
2012 & 2012
There is a video on YouTube of a guy doing it. Look up dodge ram vht night shade. He gives step by step.
nim81
Fredericktown, MO
5.7L
It just depends on dry time and humidity. Maybe 30 mins maybe longer. I used 2000 grit on mine and they turned out pretty good. Definitely use at least 3 good coats of clear coat or more
Sent from iPhone-taptalk
blackout11
alpharetts GA
2011 R/T
After you wet sand them if it below 80 and no humidity wait like 30-45 mins but let the clear dry at least 2 hours less time if its above 80
quietpeen
2021 TRX
Hellcat
i think you have to also use a rubbing compound somewhere in there
blackout11
alpharetts GA
2011 R/T
Ya final step after you let the clear dry then wet sand it then compound
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So do I spray all the coats of nightshades then wetsand it or coat, wetsand, coat, wetsand, ect?
blackout11
alpharetts GA
2011 R/T
Ok heres the best way to do it wet sand it then spray the vht (how ever many coats you desire) then let it dry after it fully dries wet sand again then apply the clear coat (how ever many coats you want ) also when spaying the coats let it dry like 15 mins between each coat.Then after the clear dries wet sand again then compound and you should have some sexy lights.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Lol ok thank you, my retarded ass needed a step by step from one person
blackout11
alpharetts GA
2011 R/T
Lol n/p at all if we don't ask we don't know believe i asked a lot of questions before i undertake anything.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Yea that's how I am, if you don't break it down for me I won't get it
quietpeen
2021 TRX
Hellcat
I say ask as many questions as you need. It gets the info in writing for other existing and new members that don't know how to do this.
68Cudaconvert
