Vibration
Patts415
Ontario Canada
Hi I got my pinion seal and all 4 brakes rotors replaced now I have a vibration driving at any speed, I can watch the box vibrate while I’m driving down the road, any ideas what this could b ???
rzr6-4
nebraska
'09 2500
Is it a high frequency brrrrrr (I don't know how else to explain it) or is it more distinct wobbles like an out of balance tire?
If you had the work done at a shop, take it back and make them fix it.
If you did the work yourself, I'd guess it's something with the brakes/wheels. If some debris got caught between mounting surfaces or you messed up bolting things down, it could have caused a wheel to be mounted at an angle that will shake as it rotates.
Coramie
Hutto, Tx
I hate to be Debbie Downer here, and I certainly hope you have better luck than me, but I just replaced my ’18 1500 with a new-to-me ‘22 1500 because I couldn’t figure out a vibration in the seat after having all brakes and rotors replaced in 2024. I dealt with it for a year and took it to multiple mechanics and shops. I got so fed up with dealing with it that I threw in the towel about a month ago. The only thing left to try was to rebuild the rear axel and cross my fingers.
JayLeonard
6.7 L Cummins
Does the vibration change with a speed change? With a transmission gear change?
Trying to separate axle from driveline.
Steve58
