jllaco
I brought the truck in for a service and upon inspection they said the middle driveshaft bushing was worn and should be replaced, they called back and said i should also do the middle u joint. All was good for about a week then a bad vibration at 26-32mph developed. My neighbor looked at the driveshaft and noticed one of the circle clips on the new u joint had come off and the ujoint was working its way out. We tapped it back in and drove it to the shop(no vibration). They installed a clip and i was good for another week, then same thing but vibration was not as severe. Check clips on all u joints and they were in place. Took it back the shop and they said they would replace the ujoint again. Got it bac, good for a week, then the vibration came back, same speed range. They checked it all out and did not see anything obvious but are going to replace all u joints. I'm not sure they are on the right path. It seems anytime that middle U joint is addressed, all vibrations go away, for a week or so. Any thoughts??
