Vibration
petit
5.9 diesel
I have a 2006 3500 mega cab diesel problem i have is i got a vibration i can't figure out where it comes. I did put new tires all the way around 10 ply that's pretty much when the problem started thet checked balance again and it's good when I go highway speed you can feel it but when I the vibration is there when I let off throttle it disappears any ideas what to look for . Thanks
MADDOG
Living in a Firepit
I'd check the tires again and this time have them road force balanced vs. just a spin balance. I've run into this very same issue several times.
Good luck!
CanuckRam1313
Ontario Canada
2023 Warlock
What brand name 10-ply did you go with?
Some are better than others.
jws123
nj
rear drive shaft center support and ujoints.
P
petit
5.9 diesel
Thanks I'll look at it and we'll let you know what I found
Hagar1
Ontario Canada
2012 Ram 1500
I once had a set (4) Goodyear tires that had shifted belts. On the balancer, they were good but on the road, scary. When we broke them off the wheels, they almost tied themselves into a knot.
According to Goodyear, they never made a "bad" tire but, I'll wager that they sold a few!
What I have found as a good easy test for a shifted belt in a front tire is to find a smooth parking lot on an early Sunday morning, driver the vehicle at a SLOW speed, LESS THAN 5 MPH. With your hands off the wheel, but close, watch to see if the steering wheel shows a slight "waddle." If it does, it is pretty much a given that there is a bad tire on the front.
CanuckRam1313
Ontario Canada
2023 Warlock
Good-For-A-Year tires are pretty much known for being garbage ;)
Look at the stock crap RSA stuff they put on our 1500 trucks as it is.
I went Michelin LTX M/S in LT295/65R20 E-Range for my summer set up and they are amazing tires that took virtually zero weight to balance out on a road force balancer.
Hagar1
Ontario Canada
2012 Ram 1500
I'm running TOYO Open Country on the truck and TOYO (I forget which model) on the van. I run TOYO studded in the winter.
Could say that I am partial to TOYO.
P
petit
5.9 diesel
I'll try it, thank you
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
Not for nothing but are they directional?
mikeynosikey444
