Vision D window Steel Wheels
Cjcollinspm
3.6 pentastar.
Okay.. so after hours of research, I think I've done it.. but I want someone like minded to check my work.
I'm about to pull the trigger on some 7 inch Vision 84 D Window in 17x8 w/ 5x5.5 (139.70 mm) bolt pattern. Wheels have a 4.00 backspace and -12 mm offset. I'll be running these on some 285/70r17 bfg ko2s.
I currently have a 2015 1500 express w/ stock 20x8 inch aluminums (painted not chromed) w/ a 19mm offset and stock 275/60r20 dueler H/Ls.
I believe I'm adding somewhere around 10 pounds per wheel but I'm not too concerned with that considering what I would've been adding when going w/ any all terrain tire in same size.
I'm wondering if this will clear the calipers without any contact. What do you guys think?? link to wheels.
Vision 84 D-Window Wheels - FREE SHIPPING from AutoAnything
quietpeen
2021 TRX
Hellcat
yes 17" wheels will clear the calipers
Franklinshaw
Clanton, Al
Really curious on how this turned out. Did you go through with the steel wheels? If so would you mind posting up some pictures? Thank you in advance!
R.L.K.
Bristol , Tn.
Yep they fit . If you look at your spare tire you'll probably find a 17" steel wheel already there . At least that's what I had on my 14[emoji106]
Klipstein
Louisiana
How did these work out?
