Warlock LED bulbs
Cylac
C A N A D A
Hello,
I just switched my headlights with LED bulbs (went with the SEALIGHTS), and I love it! Now I'm looking as swapping other bulbs to LED.
I'm just having a tough time finding the proper bulb/sizes that I need. I see several types listed on different sites, however I'm still not sure which ones I need.
I have a 2020 RAM 1500 Classic WARLOCK.
Here's what I found so far:
- Cargo Lights: 921
- Reverse/Brake/Turn Lights: 7440
- License Plate Lights: 194
- Map Lights: ? (interior)
- Dome Lights: ? (interior)
- Vanity mirror lights: ?? (interior)
Can anyone confirm or let me know the proper bulb types/sizes I need?
Also, any recommendations on the brand I should be looking at?
Thanks!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Low beam headlights
FAHREN 9005/HB3 Lights Bulbs, 120W 32000 Lumens Bright Lighting Bulb, 6500K Cool White Lights IP68 Waterproof,Quick Installation, Pack of 2 https://a.co/d/gyu7jfE
RamDiver
Marlborough, Ontario Canada
2021 DS
Cylac
Cylac
C A N A D A
All of these worked on my 2024 Warlock, with-out the need to adjust anything in AlfaOBD.
Thanks! I'll check all of these out! Hopefully, they're available at a reasonable price in Canada too ;)
Cylac
Cylac
C A N A D A
I used these in the cargo lights.
Amazon says they don't fit my truck but that's wrong. :cool:
https://www.amazon.ca/dp/B08KFS93PS?ref=ppx_yo2ov_dt_b_fed_asin_title
And these for the reverse lights.
https://www.amazon.ca/dp/B0CR41GSJ1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Both sets of bulbs seemed to fit the sockets not as well as the stock bulbs but haven't required any attention since the installation.
Both are crazy bright and a huge improvement over the incandescent bulbs.
Thanks! I'll check all of these out! ;)
itswiggs
texas
pentastar etorque
I believe the license plate lights, dome lights (except rear) and the 3rd brake light white lights are all the same size.
Marsauto 194 LED Bulb 6000K White 168 T10 2825 5SMD Replacement Bulbs for Car Dome Map Door Courtesy License Plate Lights (Pack of 10)
https://a.co/d/1EjZOFn
And the rear dome light…
warlock23
Canada
v6 pentastar
Hello,
- Cargo Lights: 921
Thanks!
I have a 2023 Warlock V6 crew cab and change the light to licence plate map, dome,vanity mirror with 194 led
https://www.amazon.ca/Yorkim-194-T1..._rp_0_1_ec_pd_rhf_ee_s_rp_c_d_sccl_2_6_i&th=1
And I change lights under dashboar with these led light
https://www.amazon.ca/Dodge-RAM-Int...i=B0BGRS57QJ&ref_=pd_bap_d_grid_rp_0_4_i&th=1
mands0807
South Tampa Bay Area
2018 Sport
Thanks!
I know on the 2018 and older, if the map lights already had LED's that like to flicker, there are some modifications that need to be done to change them. Not sure about a 2020 Classic, nor am I sure about the vanity lights, or the light over the rear seat.
kmat568613
Kindred, N.D.
2022 Big Horn 1500 Quad cab
I know on my 2022 Ram Big horn 1500 the rear dome light(578) was not very bright so I replaced it with a silvania 578 Led and its much better light and brighter.
TJP440
omaha
hemi
newbie here, just bought a 2014 ram 1500 Bighorn and would like to upgrade the head lights (go figure). I'm a bit confused on the High/low beam and fog lights. Are they all one bulb or separate bulbs.
The existing lenses are in excellent shape but appear to have a lite film on the inside. I'm trying to learn which way is best to proceed and not wanting to get into any can bus issues.
Suggestions experiences welcomed ;) BTW I'm not a Rockefeller but don't want to by cheap and then pay more later.
TIA
Also, the vin Decodes to an SLT at one site but other info says Bighorn ????
