Funkadelic
I have a 2003 Ram 1500 with the 4.7L. After engine temp warms up (gauge reads just a hair below middle line between C & H), I get warn heat out the vents, but not hot. Certainly not hot enough to stay toasty warm in Iowa in winter. Been like this for a few years now. Last fall I replaced a bunch of stuff...took out dash, replaced a few blend doors that had broken tabs and replaced heater core and AC evap core while I was in there. Also replaced the thermostat.
Thought I might have some air in the system still, so worked on the bleeder screw where the top radiator hose goes into the block, then also got it up to temp and ran a bit with the radiator cap off. Still no change in the heat.
What am I missing? What else would be keeping hot coolant to pass through the heater core? Or hotter coolant to pass through?
