Warning to all 2019 ram owners and future owners need to read
2019ramtruck
florida
soapy
Northwest
6.4 hemi
Some of the fourth generation Rams had a leaking 3rd brake light seal also.
Ryelinek
VA
HEMI 5.7
Any way to really test this to make sure it’s ok before taking delivery?
2019ramtruck
florida
So bad of water, damaged items that were under seat.
First thing I would do now is to see if the antenna fin can be moved side to side and up and down. If it does walk away. FCA dealers will not properly clean any damage that has happens my trucks interior needs to be removed and all the padding replaced. Their claim is not something they do, Also they are no concerned about any rusting issues that may happen down the road.
stimpy433
IOWA
Wow, you sure got a lemon of a truck!!! You’ve had nothing but problems...
JB1
Houston, Texas
Wow that’s terrible, sorry to hear this
DRkNESS
South Jersey
I listed the same posting but I had only had mine for less then 8 hours when I found the leak. It was coming from a improperly sealed roof antenna. Then also tested and found part of the rear window seal was bad and leaking. Thankfully it was caught before a big storm came and took me down.
Made them do a high pressure water test before I took delivery again.
Ryelinek
VA
HEMI 5.7
That’s good advise nor would I have thought to really check that prior. My truck finally started it’s build 2 days ago so hopefully I’ll have it at the end of June by the time it ships.
I did a little google search and it seems like every car with a shark fin has had some issues randomly. Lots of chatter on this for 2500 Chevy/GMC trucks. Appears to be very random but in the end it’s poor QA.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Really wished they’d come up with a different antenna design. I don’t think there is a vehicle on the planet that looks good with a shark fin.
iLLeStEyECoN
Tamarac
HEMI 5.7
This is wrong. It is a warranty issue and should be completely repaired and replaced. My father had his ceiling liner and various pieces inside replaced when this happened to his 2014.
iLLeStEyECoN
Tamarac
HEMI 5.7
Mine doesn’t move (it flexes understandably) but I do see a small gap in the back of the seal. I tried to take a picture but I suck.
793fe9b0b90b48d476fc79d49e6a6197.heic
1ea4ca735d83f5f377c8ea1cda681159.heic
SYKRAMMAN
Banned
Jersey shore
06 Mega
@op, there’s a **** ton of electrical connections under seats and behind trim on floor, also there’s electrical moduals behind the kick plates, etc, etc. All of the affected area will start to corrode and cause some funky weird **** to happen. I’d be on their or fca’s ass on this one. Jmho. Good luck, hope things work out.
Mercury250
Maryland
5.7L E torque
Why does everyone point to another company with similar issues they found? This is RAM and FCA. I have one on order, but this is just stupid. There are not very many 2019's produced and you can google it and find a PILE of issues. 12" Uconnect gremlins, leaking antenna, misaligned bumpers, clunking transmissions, lighting issues. Seriously? The more I read the more I am second guessing my decision. My dad has a FIRST YEAR in fact one of the first build 2007 Toyota Tundra and he still has it. NOT ONE SINGLE PROBLEM EVER aside from normal wear and regular maintenance. I have another buddy with a 2 year old Platinum Tundra. NOT ONE SINGLE ISSUE. But FCA products are now starting to worry me. Seems to be almost the bottom in quality. I have had a couple issues with my F150, but that started after 5 years of ownership. FCA needs to make some changes.
iLLeStEyECoN
Tamarac
HEMI 5.7
While I agree that we shouldn’t use other manufacturers as a basis, I am assuming you didn’t do the same Google search for the Tundra as they had an overwhelming amount of complaints (and still do). Like the RAM, not everyone suffers these and like the RAM, many of them were user based. People don’t come online to tell you their bumpers are aligned and they have no leaks. They come to complain. Thus, if you intentionally search for complaints, you’ll find them.
Mercury250
Maryland
5.7L E torque
True. But then you can look at consumer reports.
Jerred17
