Water Intrusion - Passenger Door
rpr
GA
2014 Ram Limited
I have an issue with water intrusion in my passenger door (2014 Limited). Doesn’t seem to happen every time it rains but when it does it’s bad, and it doesn’t empty for like a week so sim sure it’s causing issues with the interior of the door.
I have the lifetime Max care warranty but the dealer, without even seeing it, said it would not be covered because it has to be a seal somewhere.
Has anyone else had an issue like this?
1SloRam
Ms
My ‘13 RCSB does this, never got around to fixing it. Had rounds with dealer to even “fix” my third brake light leak. I’ve never had a truck leak as bad as this one. Even better by new work truck leaks too ‘19 3500 Laramie. This one is driver side pillar, think it’s coming from cab light. Probably better off tracking it down on your own.
R
rpr
GA
2014 Ram Limited
Thanks for the reply. I also had the 3rd brake light leak. That was repaired by the dealer a few years ago. This one is a bit more difficult to trace. I do have low profile AVS window deflectors but I’ve never heard of them causing leaks into the door.
