Water leak on handle of driver side door
Don Coleman
Pace Florida
Desparetly seeking answers to why I have a leak every time it rains on the handle on my drivers side. I can send a video. Need this fixed.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Door handles are not sealed and will allow water into the door. This water just drains away as there are drain holes at the bottom of each door. There is also a plastic panel between the door and the door panel that seals out the water from getting to the interior of the truck. Bet the water is coming from somewhere else.
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
I assume your talking about the grab handle. Many things can cause that. Satellite radio antenna, sun roof drains, or a leaking windshield. Some say the third brake light but I don't see that leaking that far forward. One trick is turn your HVAC fan on high, close all doors and windows. Spray the satellite antenna, windshield trim, ect with soppy water until you see bubbles. Or I'd remove as much trim as I could and sit inside while someone sprays the outside with a hose.
