Johnnymac2k6
- Joined
- Oct 5, 2016
- Posts
- 913
- Reaction score
- 520
- Location
- Ohio
- Ram Year
- 2007 Ram 1500
- Engine
- 5.7 Hemi
Evening all,
Anyone with a 09-16 hemi experience a starter that almost acts as if the battery were low/dying? but then the battery test ok, alternator tests ok? not much left besides the starter?
It'll crank kinda labored...and start. maybe 4 seconds each time. if you count our 4 seconds, its longer than normal for something with a 1-2 typical starter sequence.
battery shows 12.8 volts with engine off. dips to 10.8 on start, then up to 14.8 V with it running.
that says to me that the battery is ok....and alternator is ok.
wondering if the starter is on the verge of going bad.
replacement starter motor # is 56044736AC for an OEM.
looks like its the same for 2009-2016 rams. has yet to strand me, or "click" w/o starting, but the wife drives this truck alot...so don't want her stuck an hour from home on her work commute.
battery is barely 2 years old, and again shows 12.8V
any thoughts? thanks all.
