Weather tech splash gaurds
derag2
6.4 hemi
When I first got my truck I ordered splash guards front and rear and the fronts did not fit. Weather tech said that there was a problem.... Now I want front on and I'm just wondering if anyone with a 14 2500 has the fronts with good fit? Part number 110045....
Thanks in advance.
MADDOG
Living in a Firepit
I have their front / rear splash guards. They fit just fine. I did have to remove the front "spats" to get them to fit. WeatherTech P/N 110045 / 120024:
With the addition of the 35x12.50's it's pretty obvious I'll need to get some flares:
D
derag2
6.4 hemi
My fronts didn't fit at all... In wondering if they got put in the wrong box.... Thanks for the pics.. Weather tech said the fronts wouldn't fit the 14s, they either fixed it or were blowing smoke.
D
derag2
6.4 hemi
You think flares will fit with the weather tech's? I'm think eventually I'll get some flares also...
MADDOG
Living in a Firepit
You'd have to remove the Weathertech units, put in the flares then you will probably have to drill the flare to fasten the Weathertechs through them to the body. It may also take a bit longer fastener to cover the additional width.
Not sure how it will look but I will be adding flares so we'll see.
Ionicbrick
Maddog can you post pics when you do? I'm interested to see how this works out. I've got the factory tires and a white 2500 and I'm sick of the dirty truck already. When I put better tires I'm going to have to find a solution. I'll probably do guards and flares as well.
tim57
SW MI.
2015 Power Wagon
Found these on Ebay, RAM 1500 2500 3500 splash guard set w/ flares front and rear 82214137 82214136. Made for factory fender flares. They fit good.
MADDOG
Living in a Firepit
I certainly will. I have a black truck and it seems to attract dirt! :roflsquared:
Jvbronco
I haven't tried weather tech mud guards but I've had great luck with the husky ones
MADDOG
Living in a Firepit
Well, I can report that with Bushwhacker flares, the Weathertech molded ones will not fit.
I'll have to get some universal flaps, cut them and drill some holes in them to match the mounting and profile of the flares.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Thanks in advance.
I have the Weather Techs on both trucks, all four corners with out fitment issues (both trucks have the factory flares). I bought part numbers 110026-120026 directly from Weather Tech. This is a picture of the Weather Techs on the 3500 front well;
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
Tim57 - Did you paint those splash guards or did you find them white?
Anyone else paint them? Can you do it with a rattle can and get a decent job?
