Weird noise coming from front passenger side.
Tyler Baxley
Fayetteville
I have this noise coming from the right front side of my ‘17 1500. It’s been making it ever since I bought the truck almost 2 years ago. I have a video of it and wish I could share it. The only time it makes it is when I’m driving down the road. Doesn’t matter if I’m coasting or have the pedal to the metal. Doesn’t matter if the A/C is on or off. It still does it. The faster I go, the louder it gets. The warmer it is, the louder it is. The noise in question is hard to describe. Almost like metal or plastic scraping something. Any suggestions on what it could be? Thanks in advance for your help.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
It could be a few things. Have you jacked up that wheel and spun it by hand? Try taking the wheel off and spin the hub. That should help narrow it down.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
sounds like my wife.
Socalramfan
Huntington Beach
2011 Big Horn
Have you checked the brakes…. could Be something interfering with the wheel rotating.
Used to put a pebble or 2 in a buddies hub cap….would drive them nuts !!!
Yes, I’m sure Karma will come, lol
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I take it that you bought it used
There are a couple of things that you might check
First run a Carfax on it
or
if you know anyone that works or worked at a Body Shop, if the vehicle has been in an accident, a GOOD Body Shop employee can look at a vehicle & tell if any part has been repainted when the vehicle is out in direct sunlight
Justin33
My sorry is different but I had a metal on metal clapping sound and it took a shop a little bit to find out what it was. Apparently there was space between the pads or my truck never came with some hardware for them as the guy at shop said the play was making the metal on metal every time I went over a bump.
KAKA
