So every few weeks my new to me 2003 4.7l with just over 100k will start idling rough as if it has no/little fuel making it to the engine (reminds me of my lawn mower when I shut off the fuel line and run it until it dies; it will surge just before it dies) but the RPMs don't seem effected on the dash and a no codes are thrown and it hasn't killed the motor yet. This only happens when the engine is cold and I am not moving, as soon as I start driving away it is fine. The last time it happend I had just put the truck into reverse but had not started moving, the time before that I was in park when it happened; in both cases the truck started fine and idled fine and it was only after 10-15 seconds that the rough idle began.
Searching over the forum, I have found similar rough idling symptoms from others, but often its when they are moving slowly or happens when they come to a stop while driving. My issue seems to occur within the first minute of starting the truck. Does anyone have an idea as to what this may be?
Thanks in advanced.
Thanks in advanced.
